Splicing OBD2 knock sensors for OBD1
  • thedean
    • 262
    Has anybody spliced OBD2 knock sensors to work with OBD1? If so could you give me a diagram of the wires I need to splice? I bought a set of used OBD1 knock sensors off the forums but they look like they are in really bad shape and I am hesitant to use them when I have two great condition OBD2 ones laying around.
  • jahnaboi
    • Oct 2006
    • 1742
    From what I've been told, the obd2 knock sensors read at a different freq/hertz so it wouldn't work. That's just from the top of my head. I'm not 100% sure. If its just the plastic housing your worried about, just try encasing it with a plastic welder. As long as the continuity is still there and the metal prongs from the knock sensor itself is all intact, it should still read.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • 37829
      You need to use the correct ones.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • thedean
        • 262
        If it's a freq/hertz issue there is no getting around that. The issue I was referring to is the fact that there are 3 wires per sensor on the OBD2 ones, and only 2 per wire on the OBD1 ones.
        • Adrian_Visser
          • Jun 2006
          • 2823
          They are not interchangeable, I'm not sure if it is a Freq. issue though. I think the sensors are just fundamentally different in operation.
          '89 Alpine S52 with goodies
