Okay, heres the deal. The car is an s52 powered e30 m3 that I've been swapping for the past few months and FINALLY got it to run yesterday (wahoo!). It is an s52 with the ZF 5-speed from the e36 m3. We DID have the tranny off the motor to move the clutch and flywheel to the s52. I did NOT touch anything else. I didn't mess with the clutch fork or bearings or anything.
The car originally had an m50 in it (strange why someone put an m50 into an e30 m3 I know). But it had the ZF e36 5 speed on it, so for the swap we just disconnected the clutch slave, left it dangling, swapped the new motor in, and re-connected it (with the intention of not having to re-bleed the clutch). Re-connected the clutch slave no problem, but my clutch pedal was to the floor... it had been a few months of sitting while finishing the rest of the car so we decided to try and bleed it. So we went through the process and half way through we noticed brake fluid leaking from the bell-housing. Removed the clutch slave and the rod had broken. So, got a new one rush-ordered (since this is the only thing keeping me form driving her), put it in. Aligned it to the fork with my finger, but there was resistance trying to push it in. At this point we connected the line before trying to install it. I played with it a bit and I'm not sure what allowed it to slide into place, but it did, so I decided to tighten it up and give it a shot.
Needless to say, during in the bleeding phase we heard a loud "pop" and it broke the slave rod again.... Only this time, when I went to remove the slave... the rod didn't come out with it and is somewhere in the transmission. I tried fishing with a magnet and didn't have any luck....
SO... questions:
MY new clutch slave cost me $65 bucks so I'd really not like to blow through another one..... And I'll owe someone mega if they can help me get that slave rod out of the bottom of my tranny....
SO... questions:
- Any ideas on how to get that "F-er" out without dropping the tranny?
- Do I have to drop the tranny (ugh!)
- What the hell am I doing wrong that is causing me to destroy these clutch slaves like this?
- I tried pushing the clutch fork in with a ratchet extension and could not get it to budge (which is why I'm assuming its breaking the slave rod). Is it seized? Should I be able to feel some play with it?
- I know there is a little grove that the slave rod is supposed to fit within, do you think I just had it UN-aligned and NOT in the grove?
- Do I have to put the clutch slave on FIRST and THEN connect the high pressure line???
