413 dme no power?
  • e30shmobberr
    • 1934
    413 dme no power?
    I have been trying to find a solution to what seems to be a wiring issue that i have been having.
    I have re wired the c101 to e36 m3 harness 3 if not 4 times. I was using akg and various wiring diagrams that others had made to try to wire it but no luck. so today, i pulled the intake manifold to check all the connectors under it and they checked out. Then i rewired the c101 to the harness with the help of wedophone's wiring etms. turn key and no fire. i still dont get fuel or spark.
    i have replaced the following:
    crank position sensor
    dme
    all 3 harness relays
    I am now thinking that some how the dme (413 red stock chip) isnt getting power (no cel on with key in the one position). What is a good way to check if the dme has power?
    ive been trying to get this to crank for some time now, cause i have not driven the car in a year. just needing some help
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
  • e30shmobberr
    • 1934
    yay no reply! haha
    • mohamadr89
      • 282
      What happens when you try to crank???
      mtech 2 325ic
      http://www.r3vlimited.com/board/pict...pictureid=7968
      check out my donut vid
      http://www.youtube.com/watch?v=Tw0paUP1FEQ
      • Adrian_Visser
        • Jun 2006
        • 2823
        Can you hear the relays click over when you turn the key?
        Check the fusible link in the trunk.
        '89 Alpine S52 with goodies
        • e30shmobberr
          • 1934
          i dont hear the relays, one of my relays (fuel pump) doen not have any power to it at all.
          only thing that happens is my starter will crank.
          what fusible link do you speak of?
          • samiam3356
            • Jul 2009
            • 1901
            No power to realy at all? Meaing you can't even jump the fuel pump? If so, then you don't have shit wired up correctly. Either you've missed something on the harness or you've not got the power and grounds correct.
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • mohamadr89
              • 282
              I think I know your problem. So the engine does crank over... Did you check for spark?
              mtech 2 325ic
              • jahnaboi
                • Oct 2006
                • 1742
                Has to be his wiring.
                SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                • mohamadr89
                  • 282
                  my car had these same problems. it is probably the e30's alarm system. there is a box under the steering wheel. take off that cover and it will be located where your left knee is if your sitting in the drivers seat. if that box goes bad it wont start, you can cut the wires on each side and wire them directly to bybass the security system.
                  mtech 2 325ic
                  • e30shmobberr
                    • 1934
                    are you referring to the relay in there?
                    • dnick
                      • Apr 2011
                      • 1377
                      check your grounds. and power wires. its most likely that. it was for me!
                      • e30shmobberr
                        • 1934
                        im positive.
