m52 swap
  • polkadot_boxerman
    • Sep 2007
    • 102
    m52 swap
    To start I have a 91' 318is. I'm using a getrag 240 with m20 starter and m20 lightened stock flywheel. Everyone says you need the euro TOB when using the stock sachs clutch and the 240.
    I just ordered a stage 2 clutch kit off ebay and it came with a TOB. Can I use this one for my setup, or do I still need to order a 323 TOB.
    Thanks in advance
  • polkadot_boxerman
    • Sep 2007
    • 102
    anyone?
    • jahnaboi
      • Oct 2006
      • 1742
      IIRC you use the TOB based on which ever transmission you use.
      SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • polkadot_boxerman
        • Sep 2007
        • 102
        By your logic I would be able to use the TOB for the 318is. I thought I made it easy by giving a choice of two different options.
        1. 323 TOB- I know works
        2. F1 Racing clutch kit TOB- I don't know if it works
        • luckysnafu
          • Jun 2008
          • 262
          I have the same setup as you in my swapped car and went with the euro 323 TOB. Since you know it works you should probably use it. Don't take a chance on the other TOB not working.
          M/S52 Wiring Diagrams
          Z3M S52 to late model 325i wiring diagram
          M52 to 318is wiring diagram
          • polkadot_boxerman
            • Sep 2007
            • 102
            I planned on using the 323 one if I didn't here from anyone for the second option. how are you liking the stage 2? about as stiff as stock?
