EWS delete Help
  • IrocE30
    • Nov 2011
    • 104
    EWS delete Help
    I have a 1995 S50 with silver label 413 DME. what do i need to do to delete the EWS is that something that needs to be sent out or is it something i can buy and install myself.
    Also the motor has an existing tune on it if i use a ews delete chip will i lose the existing tune?
  • cabin
    • Dec 2006
    • 552
    You only need an EWS delete chip and yes, you can install it yourself.
    Your tune is in the chip, so yes, if you get an EWS delete chip, you will lose whatever is currently in the ECU.
    -Justin
    Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
    • 328ijunkie
      • May 2007
      • 3961
      ^ that. I sell EWS delete chips.... ;)
      Check Us out on Facebook
      Full Product Line Tuning
      • IrocE30
        • Nov 2011
        • 104
        Thanks.
        can any one show me what needs to be replaced in the ecu?
        [IMG][/IMG]
        • rlddlr53
          • Oct 2009
          • 1450
          The eprom chip is under that white bracket. You can get an ews delete chip, or you can get a chip , and clip certain wires to bypass ews
          • Fusion
            • Nov 2009
            • 3658
            See that half circle notch in the black chip?
            Refer to the picture when you install the new chip to make sure you don't flip it around like I did.
            • IrocE30
              • Nov 2011
              • 104
              what certain wires do u speak of?
              • IrocE30
                • Nov 2011
                • 104
                what if i get a red label 413 ecu and put my tuned chip in it will that get rid of the ews?
                • rlddlr53
                  • Oct 2009
                  • 1450
                  this may help.
                  e36-tech.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, e36-tech.com has it all. We hope you find what you are searching for!
                  I take no responsibility if you try this and doesnt work
                  • AirplaneBuilder
                    • 823
                    this may help.
                    Has anyone tried this? i have a s50 going in my e30 and need to delete the ews system, dont want to replace my tuned chip for an ews delete chip so cutting that wire looks simple....
                    1989 Zinno 325i S50 ZF320
                    • IrocE30
                      • Nov 2011
                      • 104
                      same boat as me exactly
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        this may help.
                        Notice how that link says e36tech? Clipping the wires only works in an e36, on a swapped e30 you need the chip.
                        The wiring is different.
                        '89 Alpine S52 with goodies
                        • rlddlr53
                          • Oct 2009
                          • 1450
                          My buddy who does these swaps on here says he has used the wire trick to disable ews on a silver label
                          • 328ijunkie
                            • May 2007
                            • 3961
                            I run silver labels in plenty of customer cars. They need to be chipped to delete the ews.
                            • MatRacer
                              • 562
                              Bringing back an old thread
                              Hi All, just about to purchase a chip for my S50 and was searching about EWS...
                              I have a 413 DME production date 04/95 and the present tune is a Jim conforti 5060-3000 with EWS delete. I got the engine in a running car. It was running with a non EWS delete chip while the 413 DME should Have EWS... How is this possible...
                              I want to purchase another chip because I bought injector and MAF and have a LWT Flywheel... Should I buy a non EWS delete since the car was running with a non EWS delete chip?
                              When looking at the 1995 ETM, the EWS module is in the chassis side of the harness. Since I don't have the EWS module and that I would connect X20 pin 18 to C101 pin 18, I would think that it would work... Does the DME receive a "permission" from the EWS module? If yes, that would go thru X20 pin 7... Could the EWS be simulated with a 12v (or ground) coming from else where?
                              Thanks for your help!
                              E30 now S52
                              2008 Suburban LTZ (Family and TT hauler)
                              325xiT (Sold)
