Will these mounts work?
  • SwiftE30
    • Jun 2010
    • 998
    for a ZF transmission with stock e30 crossmember? Just double checking with r3v before i buy.
    http://www.turnermotorsport.com/p-37...orcer-kit.aspx
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
  • giantkeeper
    • Aug 2009
    • 1416
    Yup, I am running E46 mounts on mine. Have you considered AKG or UUC?
    Always Always go for the reach around if there is an option
    • SwiftE30
      • Jun 2010
      • 998
      the ones in thew post are UUC. unless i'm missing something. It is the kit though Turner that comes with the mounts and the aluminum cups. Otherwise you would have to buy them seperatly at UUC.
      • giantkeeper
        • Aug 2009
        • 1416
        Yeah, I see that now. The only issue you may have is the indent/tab provision to keep them from twisting. Although, I do not remember that being a tremendous issue.
        Also, the enforcer on Poly is really overkill for street application. The Poly alone makes a tremendous difference.
        • Leo_328i
          • 226
          Agreed. I have UUC red poly transmission bushes in my E36 and it certainly does make a great difference alone.
          Leo.
          E30 318iS, E36 328i
          • 10Toes
            Me Father Was A Tree
            • Jan 2008
            • 61222
            How much louder are the red street and track, I have the red solid poly thru bolt race mounts right now and they are too loud.
