Intake manifold squishing spider hose
  • ayemattyyy
    • Apr 2008
    • 411
    Is anyone else experiencing this? When installing my manifold, I got the front on the studs all the way in, but the rear studs(closest to the firewall) don't go all the way down because it's squishing down on the spider hose(top valve to heater core). Opinions/insight welcome. Thanks.
    Matt
  • 328ijunkie
    • May 2007
    • 3961
    You have to bend the heater core pipes down
    Check Us out on Facebook
    Full Product Line Tuning
    • gp.plus
      • 416
      I cut about a 1/2" off mine, it was moving to much to get a good bend on it, an really didn't want to have it break on me. Just use a nice wide hose clamp an make it tight. I have not had any leaks whatsoever .
      • 325e10
        • 161
        Bent mine down using a 19mm socket
        • Jafxod
          • May 2011
          • 1301
          I cut my heater lines off in the car and ran hose out from there.
          • lolcantturn
            • 4588
            bent mine down
            Originally posted by TSI
            OEM+
