HELP! m50tu swap in an e30 gone wrong
  • sofa KING euro
    • Nov 2011
    • 414
    NEED HELP!Bought an e30 with an m50tu swap single vanos. The car wasnt running because it had no harness so I went ahead and bought an e36 harness because I heard it was the better choice for the lenth issue. I hooked everything up to the sensors correctly(used a wiring diagram from bmw) however I am now cranking the vehicle over but it won't start=/ I didnt have fuel pump engagement, fuel injector pulse, or spark but after finding the ckps to be bad I now have spark and I know the engine runs because i manually grounded the injectors and gave power to the fuel pump relay and it started=0 I'm not sure at this point if the e36 harness is whats going on because I have heard it works but I have two black wires coming out by the 20 connector on the passenger side by the firewall and I'm not really sure if they should be power or ground or both? has this happened to anyone....the dme is a red label e34 dme
  • sofa KING euro
    • Nov 2011
    • 414
    bump
    • scottinAZ
      • Dec 2009
      • 1312
      post some pics of the two wires. maybe we can help identify them (pull back the sleeves and tell us wire color as well). also check the relays are good for the fuel pump. try swapping them with the ones from your old harness if known working.
      I saved 15% on my Bimmer parts by switching to ...
      • AndrewBird
        The Mad Scientist
        • 11897
        The wires on the passenger side near the fire wall can be rather confusing as they are all shrink wrapped black. Do like scottinAZ said and unwrap them a bit to find out what is what. Brown is ground, red is positive. You could also use a continuity probe if you don't want to unwrap anything.
        • alpinescott
          • Apr 2011
          • 114
          ^^^^what Nitro said!
          • sofa KING euro
            • Nov 2011
            • 414
            YEAH I ALREADY CHECKED THE RELAYS WITH POWER PROBE 3 ALL ARE WORKING AND ALL FUSES WORK...i WILL DEF POST PICS AS SOON AS i CAN OF THe wires
            • TimKninja
              • 2131
              If your getting spark but no fuel, you might have your fuel pump lines on backwords. Feed line goes to the front of the injector rail.
              1985 325e M50TU(Sold)
              1991 318is Slicktop (Sold)
              1990 325is Brilliantrot S50/5 Lug Swapped.
              1992 525i Manual shitbox Winter Beater
              • sofa KING euro
                • Nov 2011
                • 414
                lol thanks but thats not it i get fuel pressure when i jump the relayand the lines are on crrectly and if that were the problem that would explain no injector pulse it has to be an issue with a ground loaction, harness, or DME problem because I had the engine running when I manually gave the injectors a ground and jumped the fuel pump relay
                • sofa KING euro
                  • Nov 2011
                  • 414
                  bump....anyone have these symptoms from a hall affect cam sensor?
                  • sofa KING euro
                    • Nov 2011
                    • 414
                    • sofa KING euro
                      • Nov 2011
                      • 414
                      So I peaked the sheath back on those two wires from the the e34 harness and on wire is brown with orange chaser andone has a bunch of brown wires
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        brown is ground, whether it has an orange stripe or not. those go to the shock tower ground point
                        • sofa KING euro
                          • Nov 2011
                          • 414
                          so your saying both cables should be ground no matter what correct? just wanna get this right cause the car isnt running
                          • AndrewBird
                            The Mad Scientist
                            • 11897
                            Any brown wire is ground, regardless of if it has a stripe or not. So yes, they should be grounded.
                            • zachpepper
                              • Aug 2012
                              • 9
                              same thing is happening to me and my grounds are correct. i have no injector pulse.
                              @Pepperede30
