S52 Build aka Fresh
    Originally posted by lolcantturn View Post
    Ok so you posted a picture of the c101
    ok
    *x20 ;)
    And also are you trying to run OBD1 or OBD2? You need to use the right harness for the right system....
    Check Us out on Facebook
    Full Product Line Tuning
      Originally posted by 328ijunkie View Post
      *x20 ;)
      sorry, t'was a bit hungover lolol
      Originally posted by TSI
      OEM+
        Originally posted by /\/\ III View Post
        Yes, u-turn, I'm posting pics for references... for the next guy needing pics. I plan on documenting the whole process, trial and error, right or wrong, its a learning process.
        Let me join you in the banter...I bet my car will be faster than your car when done...ha
        I appreciate it. There was a time when I knew nothing about this car and I downloaded the etk and it
        Looked like an alien language. I stuck with it, made some mistakes, learned from them and now have a running swap.
        There have been countless times where a random picture helped me solve a problem. So thanks for taking the time. It's bound to help someone sometime.
        If u need and help, Shoot me a pm, I only have like 50 posts under my belt but im happy to help when I can.
          Not trying to rip on you man just pointing out that you may be a little outta your area of expertise. You need more than 'a little help'
          YO M3.....Keep at it! I couldn't do a brake job on my car 6 months ago and have successfully completed a s52, OBD1 swap on my 91 318is. Passed emissions today with no further $ spent!
            Hey guys, thanks for all the support, I have been pre occupied with some other important matters, but I plan on picking up the project this weekend.
            My next step is to map out out pin to function.
            Cheers and be safe.
              My thought on the connector
              Taking the body plug of the e36, remove pins. Also removing pins from e30 body plug, repinning pins into new e36 body plug...does this sound right, clean fit I'm sure but will the pins be a straight fit?
              I will use the self made tool quoted in another post.
                a lot of people like to just wire in an x20 to c101 adapter or hardwire a c101 to the wiring harness. i found this to be very beneficial because If i made a mistake in wiring i could just go back and redo the connection. But then again if youre really confident in your wiring repinning would be awesome. once i got everything figured out i went back and soldered the wires together. doesnt look to cluttered.
                1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                  Look closely and youll notice why that wont work.
                  C101 Engine: Male Body: Female
                  X20 Engine: Female Body: Male
                    Dirty.
                    Current:
                    1991 325i Sedan - S50 Swap
                    1988 325i Cabrio
                    Past:
                    1991 M3
                    1991 318is
                    1985 325e
                      Yep, you can either get brand new pins from BMW and recrimp each pin, or you can just rip the harness open and splice thee e30 plug onto the e36 harness. I did the second option. I knew i was going to get the e30 m3 harness cover so i just did away with the old plastic box cover, removed all of the sheathing and stuffed it all under the cover. I managed to fit everything under the cover so i cut off the loop that originally holds the c101 connector also.
                        ^^this. repinning is just uneeded hastle.
                          Please double check my wiring loom table for the x20, I have been away for the holidays, but picking up the project again. Happy New Year. Thanks.
                          1 blank
                          2 blank
                          3 blank
                          4 black/blue 0.5 AC Compressor relay
                          5 black/gray 0.5 Aux fan
                          6 violet/gray 0.5 Internal climate reg ?
                          7 green 0.5
                          8 gray 0.5 Check engine light
                          9 blank
                          10 blue/yellow 0.75 ?
                          11 brow/yellow 0.5 Coolant temp gauge
                          12 brown/violet 0.5 Coolant temp sender
                          13 green/violet 0.75 Fuel pump relay
                          14 black/white 0.5 Oil level ?
                          15 black/green 0.5 Starter motor
                          16 white/yellow 0.5 ?
                          17 white/violet 0.5 EWS ?
                          18 black/yellow 1 Starter ? Diagnostics?
                          19 white/green 0.5 Diagnostics connector
                          20 black 0.5 Engine spped from EGS
                          21 green 1 Ignition switch
                          22 green/white 0.75 ?
                          23 brown/green 0.5 Oil pressure switch
                          24 white/black 0.5 Fuel consumption
                          25 blue/yellow 0.5 Altenator
                            wrong. :/
                              thanks 328junkie, but what part of it is wrong?
                                1 blank
                                2 blank
                                3 blank
                                7 green 0.5
                                9 blank
