I have the same issue, sub'd to see how you go and if I find anything that sorts mine I will let you know
HELP e30 m3 s52 swap - Runs but - Coolant Temp Gauge not working... toltally stumped.
Originally posted by der affefirst try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door. -
Are you using an m20 sensor? And you shouldn't have to take the intake off to get to the sensor..I never did..
90 325is alpine2 m50b25 becoming a dorifto car.Comment
Yes it's an m20 sensor. And it was re-threaded by Market Motorworks to fit into the old throttle body coolant line hole on the block for the swap.(oo=[][]=oo)
Web Design PNWComment
Dammit I was looking for resolution here as I'm running into the same problem. I'm pretty sure I'm bled and am not overheating but I'm not going to drive her hard until I find a solution. I'm also running the aluminum inline adapter where the sensor is fed into the throttle heater line. Hopefully my ground from the adapter isnt the issue.
I've also done the same thing where I modded the harness vs using an adapter. I'm also using an m20 sensor.
Here's the inline adapter for anyone curious. http://www.zionsvilleautosport.com/s...de/OBDITSM.htmLast edited by drumad; 12-05-2011, 08:57 AM.2008 335i - n54b30
1991 318i - m52b28
1994 fzj80 - LAND CRUSHERComment
Here's the inline adapter for anyone curious. http://www.zionsvilleautosport.com/s...de/OBDITSM.htm(oo=[][]=oo)
Awesome. I will try this upcoming weekend. I'm thinking my ground is probably just insufficient as its just a 16 ga wire going from the adapter to the block. I'll try it again. Good to know you have actual experience with it.2008 335i - n54b30
1991 318i - m52b28
99% sure its the ground. If it was working and in fact had a big air bubble, it would still move a little. Although I have an S50 swap, I had my temp gauge AND fuel gauge drop to zero and stay there. A tap on the cluster lens did the same thing, made them jump but then they became really erratic. Turned out they were both ground issues. This was after I bought a new cluster board and ripped out some hair. Turned out to be an easy fix.'87 325ic, powered by S50.Comment
Okay, so I'm now suspicious of the water pump. I'm going to take the upper radiator hose off tomorrow and see if water comes out when I turn the car on to confirm (unless someone has a better idea). But my thought on this is that maybe its not circulating and there is still air in the system / at the sensor. We'll see what my test yields tomorrow...
I'm still unsure as to why my needle wouldn't jump when I tried to ground the harness side wire. I'll try "e46s54dr" suggestion next. I don't think that's my issue but we'll see.
Anyone have a good suggestion of which / how to install an aftermarket gauge to test?(oo=[][]=oo)
I doubt its the pump. Wiring issue or the sensor. If you want I can send you another, im still stuck on it being a wiring issue tho
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Sorry for this question, but I have the same problem. My temp sensor bumps up once and never moves.. My harness I know is fine and I labeled all my conectors, and my temp gauge worked fine before swap.. Am I reading correct but I have to ground the M20 sensor to the block?? I just didn't understand what I read.Comment
To answer your question: You only need to ground the sensor if you're running it "inline" and its not threaded into the block. This would be the case if your sensor is the "T" style running through your throttle body coolant lines. If its normal and threaded into the block, then its already grounded by the block.(oo=[][]=oo)
PS, Try to find another cluster to swap over to see if anything changes. That might be the easiest way to verify a faulty cluster.Comment
No, I'm the OP with no solution yet.
To answer your question: You only need to ground the sensor if you're running it "inline" and its not threaded into the block. This would be the case if your sensor is the "T" style running through your throttle body coolant lines. If its normal and threaded into the block, then its already grounded by the block., I work six days a week now and no time to tinker with it. I'd like to read what this issue is. Thanks again.
Test it by replacing the SENSOR with a resistor or ground the wires going to the sensor and see if the gauge moves. If it does not, it's your wiring and/or cluster.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
If I were to try a resister on it, what resister would I use?(oo=[][]=oo)
