M20 exhaust with swap
  • SHunter
    • Dec 2010
    • 154
    Who here is using an M20 exhaust with their swapped car?
    I'm not looking to make a million horsepower or a bunch of noise. I'd like to make at least the 190hp of the stock m52b28 and I like the sound of the exhaust on my M20 car now. I have a no name SS catback with no resonators. By my measurements the tubing is twin 1.75" coming from a hollow cat with a 2.25" inlet. It's surprisingly quiet with only a muffler but has something to say when I get on it. The thing is, Magnaflow shows a cat with a 2.5" inlet and twin 2" out for the m20. Did the PO "upgrade" the car with a smaller exhaust??? You guys think I can make this work with some m52 headers and custom downpipe or will it be too restrictive for the slightly larger engine? I do plan to run a new cat BTW.
  • scottinAZ
    • Dec 2009
    • 1312
    bone stock, the exhaust is 1.75 inch dual from the downpipes. I am running a modified stock exhaust on my swap. I used ebay SS replica headers into modified downpipes into the stock exhaust. Ebay ss reps are a bit odd, as one header steps down to 1.75 inch already, and the other is at 2" requiring one reducer. only things I needed to source for the exhaust to work was a couple of 1.75 inch straight sections and said reducer. all bends were scavenged from the original exhaust downpipes.
    I saved 15% on my Bimmer parts by switching to ...
    • SHunter
      • Dec 2010
      • 154
      Hmmm...So no x-pipe for you? Or does the stock cat merge the two sides?
      I was thinking about using these headers since they have dual O2 bungs and I'm going with an obd2 engine.
      http://www.ebay.com/itm/BMW-E36-323i...item35b6f84544
      I would be needing a y/x-pipe into the cat or need to find a cat that acts that way. Anybody know if the e36 dual in/out cats are separate all the way through or do they act like an x-pipe?
      • jahnaboi
        • Oct 2006
        • 1742
        What I did:
        Obd2 Headers > Obd1 Midpipes (Modified with e30 flanges to accept e30 exhaust) > E30 stock exhaust. Quiet as hell.
        SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
        • scottinAZ
          • Dec 2009
          • 1312
          No X-pipe, everything merges as per the stock exhaust (not counting the dinky pipe in the downtubes that the o-2 sensor mounts in on the stock M20 exhaust)
          I cut the stock exhaust about 8" forward of the cat, scavenged the bends to fit into the header collectors, and called it a day.
          collector to cat bend:
          View into cat:
          these are the best pics I have right now, its a bit of a pain in the ass to get under the car for better pics....
          • trackjunkie21
            • Jan 2010
            • 3962
            Any vids on how it sounds? Would love to hear it!
            Originally posted by Wh33lhop
            VANOS: sometimes you just need to go full retard.
            • scottinAZ
              • Dec 2009
              • 1312
              best I got right now
              • MaxBell
                • 1391
                Not bad. I may even just run the stock M50 exhaust manifold for now.
                REMEMBER: Be safe and have fun is Rule Number 1.
                The Epic Unbuild of Clint Eastwood
                • scottinAZ
                  • Dec 2009
                  • 1312
                  as long as you have the E36 downpipes to match to the manifolds and the exhaust, you are good to go. I didnt have them, and given the fact I would need to fab anyways, I went with the headers. Less headache and hassle.....
