s50 swap into e30
  • joecassie
    • Jun 2011
    • 90
    s50 swap into e30
    im doing a swap and would like to know what oil pan gasket i need. im using a 525i oil pan
  • Jafxod
    • May 2011
    • 1301
    You need the 1984 318 one.
    • ScHpAnKy
      • 1573
      525i one, I recommend a gasket sealer too.
      91 318i | 87 535iS
      • Fidhle007
        I can fly, motherfucker
        • Oct 2005
        • 7209
        +1 Seals better then one that would actually fit!
        '89 325is S50 Track Montser
        '04 X5 Daily/Tow Vehicle
        http://www.avarestoration.com
        http://www.myspace.com/brendanfiddle
        Click here if you want to be my zombie slave...
        http://www.youtube.com/user/Fidhle007
        • joecassie
          • Jun 2011
          • 90
          thanks why cant you use the gasket from the m3
          • Fidhle007
            • Oct 2005
            • 7209
            Too much Power.
            • trackjunkie21
              • Jan 2010
              • 3962
              because no racecar
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • scottinAZ
                • Dec 2009
                • 1312
                just use RTV silicone. Preferably a couple of caulking tubes of it. Multiple colors to make sure you cover all applications and it also looks pretty.....
                I saved 15% on my Bimmer parts by switching to ...
                  • 37828
                  I prefer the common sense gasket. Hard to find though.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • White325is
                    • Oct 2006
                    • 5947
                    ^ that one is my fav, autozone seems to always have it in stock.
                    • Fidhle007
                      • Oct 2005
                      • 7209
                      Sadly none of there employees can ever find it for you unless you have a part number...
                      • ScHpAnKy
                        • 1573
                        i. died.
                        LOL
                        91 318i | 87 535iS
                        • e30rapidic
                          • 2167
                          what about the PVC one?
                          '87 325ic, powered by S50.
                          • White325is
                            • Oct 2006
                            • 5947
                            thats so fuckin true..
