E36 Auto to Manual Wiring Harness Conversion.
What pins are those 3 wires from the EGS Harness?
I can find the ABS one referenced in the pinout, but not the other two youre talking about -- is it the DKT?
Are you using this diagram? I have found it to be a little less complete than the ETMs, even though working through the pins is a little more involved
The ABS is listed as an input for the EGS, won't need it to run. Also, remember that if theres nothing plugged into the EGS harness (ie running it in a 5sp) it would be just like removing it anyways. If the wires run directly to the DME, remove the DME pins. If they run to a splice in the body of the harness, remove the EGS wire from the splice and you should be fineComment
I found the link to all of the ETM's I used for the swap. Just look up your, and the donor E34/36 harness by year and you'll have all the information you need. I had also read about E36's using a dummy relay in the place of the auto transmission selector, but I didn't have to make any mods to the trans wiring like scottinAZ just mentioned.
Just copy and paste it and you'll be directed to a listing of the ETM's by year and series.Comment
No problem. Honestly, after studying the schematics it was enough information to eliminate the auto section of the harness and get everything working properly. There are many knowledgable people on this forum. I read through countless thread pertaining to this swap just to get an idea of what to expect and what the most common problems other people were experiencing. What exactly do you need more information about?Comment
Off hand
I think you'll find that red/white/yellow whatever wires is emissions related, and designed to go back to the gas tank emissions vapor management etc.
You don't need it.
Really, the ETM is your friend, and since you have the wires in hand, at some point, you should have been able to see what pin they came off either the DME for the engine, or the DME for the trans...that gives you the first clue or knowledge about what they are.
The other thing to keep in mind, even though we have a very complex engine management in the BMW, remember, that the X20 is only communicating a very limited amount of information to your car's chassis in this case:
Key on ignition
Tach
fuel pump power
rpm
Idiot light for oil pressure
CEL potentially
Charge light for alternator
Coolant temperature
And the E36 for packaging reasons sends the two reverse light wires to the X20 so that the wires to the switch on the trans come down from the engine harness with the O2's etc...
That is of course off the top of my head, but you get the picture. Everything important is between the dme and the engine really.Comment
Ok guys, thanks for the help. I've got the harness almost all together.
One question regarding oil temp and how I go about wiring that.
Another question I have is about the coolant temp gauge in the head. Where is that wired into the harness? Which sensor do I splice? Which sensor should I use? (just the little one off my M20?)Comment
I know there have been other posts that explained how to wire up the oiul temp sensor. I honestly don't know since my car does not have an oil temp gauge.
I used the M20 water temp sensor for the gauge and it screwed directly into the head in the place of the original E36 sensor. Its the second one, the first temp sensor is for the DME and has blue tape around the plastic connector. The E36 temp sensor connector is idectical to the M20's As far as wiring the temp sensor, I just matched the wires to what would connect to the single pin on the M20 sensor. It was purple with either a white or gray stripe. That wire goes to the X20 and from there you can connect it through the C101. I just took the ground wire for the E36 temp sensor out of the harness. Hope this helps!Comment
That's awesome! Thanks tcanin00. Just to clairfy, is the right-most gauge a coolant temp or oil?
rightmost gauge is coolant temp.
Just for the record, I left the coolant temp sender wiring alone. Replace the sender, but there is no need to modify the wiring going to it on the M50 harness, the connector will mate right up to the M20 sender, wiring will be correct
I read about 1/2 way on the gauge during normal operation.Comment
Yes, like scottinAZ metioned, it plugs into the M20 temp sensor directly. I removed the E36 ground wire because I hate the idea of "dead" or used wires in a harness. BTW MaxBell, what instrument cluster is that? I believe the gauge in the bottom of the tach is for oil temp, since it reads higher than a coolant temp would.Comment
