E30 M3 S50 swap what wires stay and what GO?
  • rjd2
    • Sep 2005
    • 27
    I've got a buyer for the blown S14 and I don't know what I can let him take as far as wires in the engine bay/ inside the fire wall. Do the adapters you can buy from tree house racing plug into all the S14 plugs going to different sensors??
  • kylebes1
    • May 2004
    • 2804
    or the ones you can buy from me....
    • rjd2
      • Sep 2005
      • 27
      ok I'll buy them from you but what should I keep with the car and what should I let the guy who wants the motor take?
      • cheades
        • 632
        You can let him take everything attached to the motor. You only need the plug going right from the firewall.
        • 325Projectz
          • Jan 2005
          • 1956
          I'm going to need one, soon. How long will it take you to make me one and have it shipped out?
          95' motor, 91' m3
          91 m3
          • 1990m3
            • 1180
            the big harness with a bunch of wires going various plugs in attached to the engine seems to double back and connect the the harness going through the fire wall to the interior and to the fuse box. Basically there are about 5 or more wires that seem to go to the ecu that are coming form the engine harness. Can I cut these or do i need to follow them back to the ecu?
            • rjd2
              • Sep 2005
              • 27
              that was my question using his computer....
              • X2theZ3
                • Mar 2004
                • 932
                Do you have a bentley?? Just follow it if you do. A regular e30 bentley cover m20 engine removal: it should be very similar for your engine.
                You shouldn't have to "cut" anything.
                • rjd2
                  • Sep 2005
                  • 27
                  what about the wires going into the fuse box? I've got everything lose but those. I took the cover off the top of the box and it looks like they are hard wired in.
                  • joshh
                    • Aug 2004
                    • 6195
                    The engine harness will come out entirely with end connectors and all. If you have to cut anything....your fucked or your trying to remove the wrong harness.
                    You don't need the wires to the fuse box unless your doing something weird with the car.
                    I also took the o2 sensor wires and sensor for good measure.
                    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
