Was M50 vanos w/ red 413
  • newolde30
    • Sep 2009
    • 92
    But she blew up.
    So, if I put a M50 NV in, I think Ii will need a green label 405 or a 402?
    What about my existing harness - can I use it?
    Also, is putting S50 cams in in the NV M50 going to complicate matters with respect to the 405 or 402?
    Any help would be appreciated.
  • MaksV
    • 1042
    You cant run s50 cams in a NV m50. you can run two NV intake cams for a little more power if you want. You need a 402, 403, or 405 DME. They will all be the same.
    I believe you need a NV harness, but I am not sure.
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    • newolde30
      • Sep 2009
      • 92
      Thanks.
      Interesting on the cams - when you say a little more power, would you say negligible, or noticeable?
      • rares
        • 730
        i would say maybe 14-20 hp.... i could be wrong
        • MaksV
          • 1042
          The intake and exhaust cams have the same duration if I remember correcly, however the intake cam has 11.5 lift vs 11 for the exhaust.
          You can run two intake cams, and make a little mroe power maybe ~10hp crank, or you can put the intake into exhaust and get the schrick intake cam. Then you probably need a tune to get the most out of it. I run both stock cams and am quite happy with the power in my e30.
          Guys learn to use google. Some useful info here:'
          You apparently need to grind the new exhaust (actually the second intake) cam down to fit.
            • 37829
            It's really not worth the cost or trouble to bother with cams on a M50 NV. Enjoy as is or prep for a vanos engine swap.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Adrian_Visser
              • Jun 2006
              • 2823
              Don't forget that the 60-2 wheel and crank sensor are different on NV so they would need to be swapped too.
              '89 Alpine S52 with goodies
              • 328ijunkie
                • May 2007
                • 3961
                Whats the difference between the NV and V crank pulley? The PNs are different but whats the real difference?
                Check Us out on Facebook
                Full Product Line Tuning
