89 325i w/ s52 OBD1... so i finished hooking up all the vacuum hoses last night. this is what i have...
on the intake manifold; w/ the turner motorsports m50 conversion kit fyi.
1) ICV plugged into intake manifold and a hose to throttle body
2.) One small vacuum hose to FPR that is at the back of the fuel rail
3.) other two vacuum connections (one big, one small) on intake manifold are plugged.
4.) the OBD2 valve cover with original hose to PCV (circle thing with cone shape bottom) other end of PCV not hooked up.
when i finished putting things back together last night it started right away and idled fine for about a minute and then the CEL came on so i turned it off.
Today i hooked up the bottom connection to the dipstick (using original obd2 with hose connection)
after hooking that up the car started but wouldnt idle and the rpm's shoot up when pressing accelerator and hesitate to come back down.
It also smells a lot like gas when trying to start it. It seems like its flooding a bunch.
please help. I was really looking forward to driving it today, but ran into this problem. Its always something..
oh, and i am using an OBD2 Dinan TB. it came with the donor car i bought. i have an obd1 TB i can swap over if that is the problem.
