Best m50/s50 years?
  • E30_pilot
    • Sep 2005
    • 1461
    Best m50/s50 years?
    Is there a certain m50 or s50 year that is more desired for the e30 swap? and for the m50 from the E36 or E34 better, same or doesn't matter? also for the 2.5 or the 3.0 m50, each is more better for the e30?
    Thanks much....
    -Frank
    1987 325is m50nv (schwarz)
    1990 325is (sterling silber)(sold)
    2001 525i
  • Jarvis
    • 2132
    '92 325i was NON-VANOS (M50B25), 93-95 had VANOS (M50TUB25).
    Only the '95 M3 had an S50 (S50B30US).
    Anything newer than that and you're talking about OBD2 motors - which add ~$1K to the swap to do it right, but ultimately have more power potential.
    Well you need the oil pan and pump from the E34 anyways, so it would be slightly more convenient to get an M50 from an E34 instead of E36. But E36 M50s have longer wiring harnesses - that way you can route the ECU back to the stock E30 location. IIRC E34 wiring harnesses are too short for that, so you'd have to mount the ECU under the hood where the battery is on cabrios.
    • E30_pilot
      • Sep 2005
      • 1461
      thanks for clearing that up for me....
      -Frank
      2001 525i
      • Ferret
        • May 2005
        • 101
        Keep in mind if you get an E34 engine that you'll need E36 exhaust manifold and aluminum engine mounts.
        • KangamangusDriver
          • Aug 2005
          • 1870
          As well as E36 engine arms since the E34 do not fit the mounting points on an E30. Keep in mind you will want to run a tap through these fittings on the block of the M/S50. It will help the when bolting the engine arms in.
          • 86325e
            • 228
            I used an E34 motor and was able to pull the relays and DME in through the stock location.
            Eric
            85 325e M50 and auto to manual transmission conversion...
            • asubimmer
              • 6482
              so would it be better/easier to use a e36 or e34 m50?
              • 86325e
                • 228
                I felt it was easier to go with an E34 engine and just get the E36 engine mount arms and thats what I did. The E36 harness is a little longer though. Personal preference
                Eric
                • asubimmer
                  • 6482
                  cool cause i think i am going w/ the e34 just wanted to know what others thought.
                  • E30_pilot
                    • Sep 2005
                    • 1461
                    i think i might go with the s50 swap.
                    now it's a matter of finding the engine lol
                    -Frank
                    2001 525i
