Pics of Labeled Harness
  • khnordeen
    • Oct 2007
    • 459
    Hey r3v,
    Got my s50 back in my 318i and mounted up and I am getting started on getting everything hooked back up.
    I was hoping somebody would happen to have a photo or something of the harness labeled with where each plug and connector is supposed to go to help me eliminate some of the guesswork since my harness wasn't labeled at all when I received it.
    Thanks for any help.
  • blackhawkimpact
    • 2415
    • 328ijunkie
      • May 2007
      • 3961
      Is the C101 already taken care of?
      I label all my adapted harnesses ;)
      Check Us out on Facebook
      Full Product Line Tuning
      • Mako18
        • Jul 2006
        • 688
        multimeter and ecu pin out
        • khnordeen
          • Oct 2007
          • 459
          http://www.markertmotorworks.com/Cus..._Harness_.html
          I actually bought the motor from a local shop and they supplied an adapted harness with the motor.
          I'm just trying to figure out where all of the plugs and connectors for the various sensors go.
          Feelin' kind of stuck.
          • Jafxod
            • May 2011
            • 1301
            Pull the rubber boots back on the connectors
            oil pressure sensor BRN/GRN or BRN/GRY
            front coolant temperature sensor (ECU) BRN/RED BRN
            rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
            crank position sensor YEL
            cam position sensor YEL RED/WHT BRN/ORG
            VANOS solenoid RED/WHT GRN/BLU
            knock sensor, 1-3 BLK NCA DME PIN 70
            knock sensor, 4-6 BLK NCA DME PIN 69
            throttle position sensor (TPS) BRN BRN/BLK RED/YEL
            intake air temperature (IAT) sensor BRN GRY
            idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
            Evaporative emissions valve BRN RED/WHT
            • khnordeen
              • Oct 2007
              • 459
              Thanks a lot for the help!
              I seem to have all of them, except I have a quick question concerning the crank position sensor. I know you have it listed as YEL, but I have one three-prong plug left that has three wires; black, yellow and clear.
              Is it possible that this is the corresponding wire for my crank position sensor?
              • cormier
                • 380
                Use a multimeter and e36 ETM, its the only way to be sure and you'll have peace of mind knowing everything connects the way its supposed to. You can figure out that connection in like 5 seconds and won't have to rely on wire colour
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  Yes, YEL is the actual wire in the plug that is the signal.
                  Originally posted by 325Projectz
                  don't listen to the diagram... listen to mr. swiss.
                  :nice:
