What are you doing for IAT sensor placement and running the IAC and having some provision for PCV from the valve cover? The silicone boot I got has 2 small spots in the underside and I have my IAT sensor shoved in one and the IAC going to the other and just a breather filter on the VC opening. Wanting this to be connected to the intake obviously...
OBD2 Guys
I rethread OBD2 IATs to go into the OBD1 port ;)
Check Us out on Facebook
Full Product Line Tuning
