Only running on cylinders 1-3?
  • bacain32
    • 168
    I got my swap wrapped up and fired it tonight, but I'm only hitting on cylinders 1-3. It was idling rough and had zero throttle response, so I took a look at the headers and 1-3 was discoloring and hot, 4-6 you could grab with your hand, so immediately I shut it off. I checked for spark on all the coils, all are good to go, the injectors are firing for every cylinder as well. The engine is an M50TU with red label 413, I tried 2 different DME's as well, same issue. Another thing is I don't even have the O2, or purge solenoid plugged in and I'm not getting any codes for them either, but I know those can be time delayed codes as well. Any advice is GREATLY appreciated, thanks in advance.
    '97 M3 LS3 V8, '90 S54 325i, '90 325i touring, '99 540i touring, '94 325is
  • bacain32
    • 168
    Got everything figured out. It was a coincidence that the back 3 injectors were all stuck closed, I got them freed up and it runs like a champ!
    • Sagaris
      • Sep 2009
      • 2243
      Nice detective work!
