Looking for the right cooling setup for dc traffic
M50 overheating
Tags: None
M52 80C thermo stock M20 rad 82C fan switch, stock AC fan. Never past a little over middle.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Id put an electric fan in, Its cheap and easy and have no worries. 80 degree thermostat and I used an 82 degree fan switch to turn it on earlier. Never had a problem even idling at the track in 100 degree days.Comment
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
