Exhaust Round Two.. help me sort this biz... - e30 m3 s52 obd1 swap
  • trackjunkie21
    • Jan 2010
    • 3962
    Those are the Euro rep headers, not the raceland reps.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • r4esh
      • Jan 2010
      • 439
      Well I'll probably have to take all that heat wrapping off in order to have someone manipulate these headers to fit properly, so maybe I can get an indication of what they are exactly then... either-way they need serious adjustment to fit without spacers.
      Sorry I'm a lame ass and keep forgetting to post my emission scores...
      I don't want to repeat this process again and don't want to buy "cheap" cats. Can someone recommend a GOOD set of Cats / Resonators for my setup? I need to order these asap.
      P.S. - YES in the pic the O2 sensor isn't plugged in. Those were pics when the JUST finished the welding on the entire exhaust. But as of now it IS plugged in.
      It'll probably be expensive, but I'll probably have someone professionally cut / weld up these headers to work.
      (oo=[][]=oo)
      Web Design PNW
      • trackjunkie21
        • Jan 2010
        • 3962
        OBD2 headers are where it's at.
        • r4esh
          • Jan 2010
          • 439
          IS there anyone here that ISNT convinced its my cats that are bad? I don't want to spend all this money if that is not the actual issue you know? Maybe I just need to drive / burn off more crud that has been collecting in there while we did the swap? Just a thought...
          (oo=[][]=oo)
          Web Design PNW
          • cale
            • Oct 2005
            • 2331
            I'm guessing you're expected ot meet the restrictions of an original M3 and not that of the motor you swapped in? There's no way in hell cats with 130k mile's on em are going to be capable of getting you a pass.
            • r4esh
              • Jan 2010
              • 439
              When we did an m52 OBD1 swap in a 325is e30 with 150k miles on the cats it passed emissions no problem. Are you thinking this is because both engines were 6 cylinders? And now I'm going from the original 2ltr 4 cyl to a 3.2ltr 6 cyl and thus not passing?
              (oo=[][]=oo)
              Web Design PNW
              • rlddlr53
                • Oct 2009
                • 1450
                I am thinking it may be software issue. I passed easily with turners chip with s50 and same mods. I think you may wanna try different software, and I forgot if you have new plugs.
                • r4esh
                  • Jan 2010
                  • 439
                  Brand new NGK-Iridium plugs. Tuning from TRM. I'll call them tomorrow, but the car runs so smooth that I don't think its tuning. I suppose I can take it someone to have the cats tested... that is the next step I guess.
                  (oo=[][]=oo)
                  Web Design PNW
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    There are many ways to check an O2 using a voltmeter (preferably a scope). Also a laser temp gun helps for pre and post measurements.
                    I would ask for the most conservative tune possible for your S52. And start from there.
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • Jalves619
                      • 596
                      I'm pretty sure I have my 506 w/ a stock s50 tune, a full set of green tops, and my OBDI MAF in Tucson right now. It may run a bit lean, but not dangerously lean. Just a thought....
                      • r4esh
                        • Jan 2010
                        • 439
                        So finally posted ^ my emissions results. Maybe this will help determine what the issue is. I'm not really sure what causes each thing to spike, so any input would be great. Still think my cats are bad?
                        (oo=[][]=oo)
                        Web Design PNW
