3 Radiator Choices, Which one do I use?
  • Tico Frank
    • Feb 2011
    • 351
    I will be swapping my m50 in the next few days and I have 3 radiator choices.
    #1 E36 M3 Radiator
    #2 E36 M42 Radiator with the reservoir on the side.
    #3 Stock E30 M20 Radiator
    I would like to use the E36 M3 Radiator but I have never seen a pic of one and need to know if it would use the stock m20 reservoir?
    If you have a preference please explain why, thanks
    I would like to sell the other two as I don't think I need 2 extra rads.
  • 328ijunkie
    • May 2007
    • 3961
    stock E36 and late M20 rad are basically the same.
    Check Us out on Facebook
    Full Product Line Tuning
    • MaxBell
      • 1390
      I'd go M42 rad. It's been great for many people in combo with a SPAL (or similar 16" electric fan). It's a cleaner engine bay too.
      Unless you're doing a lot of hot summer traffic idling, you won't have any issues with it.
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • 5KWattson
        • Apr 2009
        • 809
        e36 all rads are the same as m20 88+ rads, M3 or not no difference the only e36/7 that has a different one is the Z3M, but the m20/e36 rad is fine, the 24v motor really doesnt require any extra cooling that is able to fit under the hood of the e30 chassis
        "God created turbo lag to give V8's a chance" Taylor D.
        • TimKninja
          • 2131
          The m42 radiator can be a bitch to bleed but cleans up the engine bay nice. E36 radiator and late model m20 are practically the same.
          1985 325e M50TU(Sold)
          1991 318is Slicktop (Sold)
          1990 325is Brilliantrot S50/5 Lug Swapped.
          1992 525i Manual shitbox Winter Beater
          • Killacortes
            • 1937
            I choose the m42 as well. Works great looks even better
            r3v does not fuck around. First you get banned, then they shoot you
