WhAt drive shaft do I use in a s50 swap
  • joecassie
    • Jun 2011
    • 90
    I have the transmission from a 95 m3 so what drive shaft should I use
  • sharky
    • Jan 2005
    • 2672
    4 bolt rear shaft from96-99 e36 m3 or 328
    • Acehye559
      • 1033
      Which transmission you going to run?
      • SwiftE30
        • Jun 2010
        • 998
        OP....
        go with this. allows you to keep the stock e30 driveshaft
        https://www.revshift.com/shop/24v-sw...dd8d021b6f68d7
        if you dont want to go that route and dont have your stock DS, you can use any 4bolt DS from 96-99 m3. or one from an e36 328i.. IIRC the 4 door 328i DS works too. or if you can find one, an e30 m3 DS, which would be awesome!
        1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
        • Acehye559
          • 1033
          Oops Im blind... +1 on the revshift. However make sure your zf tranny has the right flange that works with the revshift 24v flex disc.
          Heres a pic of the flange that doesnt work:
          Revshift is a performance engineering and manufacturing company located in Metro Detroit, MI. Our parts are designed and manufactured under one roof. We design, engineer, and test the parts ourselves. Engine / motor mounts, bushings, suspension for BMW E28, E30, E34, E36, E46, E8X, E9X, F22, F32, F8X, Z3, Z4, N54.
          Heres a pic of the flange that does work:
          • SwiftE30
            • Jun 2010
            • 998
            True, True. I have a zf from a 97 m3 in my e30 swap, but for some reason i had the first on you posted. i guess it was from a 318 or something. So i had to grind it down a bit in order for the bolts to fit. Since it is so close to its rotational axis it doesnt need to be exact when grinding it down.
            Took me about 20 min and it bolted right up. no vibration at all.
            • Wanganstyle
              • 2828
              https://revshift.com/good-flange.bmp
              that item will not work for any of the Getrag 6 speed or ZF 6 speeds then
              318's have transmission output triangle flanges incompatible with a ZF SG310/320 gearbox.
              e34 525i 1991/2 m50b25 non vanos had ZF Sg310
              1995 usa m3 s50b30 had zf sg310
              1996-1998 e36 M3/328i had ZF sg320
              e39 528i had zf sg320
              e46 330i had zf SG320 in the 5 speed varients.
