M50 Harness labeling help
  • SpeedRacer85
    • Jul 2011
    • 424
    Hello I've done all the rest of the connectors except three if anyone could let me know what they are I will be greatful here are the pics and wire color. It's a vanos harness.
    Ok the first one I think its the oil level sensor in the oil pan? BLU/WHT, BLU/YEL, BRN/ORG
    Ok the scond one is BRN/GRY, or BRN/WHT I think this is the oil pressure switch
    Third is BRN/YEL, BRN/VIO not sure about this one?
  • 328ijunkie
    • May 2007
    • 3961
    3rd is cluster coolant tem. youll need to plug this into an E30 cluster sender.
    2nd is oil press
    1st is OLS
    Check Us out on Facebook
    Full Product Line Tuning
    • SpeedRacer85
      • Jul 2011
      • 424
      Thanks a lot I just needed clarification, I also Ordered a coolant temp sensor from your shop which was a great fit in my s52 head thanks again.
