m50NV OEM clutch-flywheel-TO w/ Getrag 240????
    SO.....
    I bolted up my 91 318is getrag 240 to my m50 block from a 1992 e36 325is and did not make the change to the single mass m20 flywheel clutch and starter. AM I FUCKED as in this will not work, or just "dumb" for keeping a dual mass.
    After micrometering the thickness of the e36 dual mass / pressure plate and clutch against the stock e30 42 one, they were strikingly similar and the throw outs seemed identical. The measurements weren't exactly equal, but within what i would assume are the allowable play in a throw out bearing/fingered pressure plate design. The only difference was a slightly longer pilot bearing surface on the shaft of the e36 getrag 220 (yes a 220 came on the 1992 325 ..dont ask its an odd model) than that of the 240. They both had 10 spline shafts that matched.
    After extensive searching I cant seem to find anything that say definitively either
    A) yes the OEM dual mass flywheel and clutch from a m50NV will work with a getrag 240
    or
    B) no the oem m50NV flywheel/clutch WILL NOT work at all !!stop your swap now
    Can someone please answer this and support there answer with experience or reason.
    Thanks.
    Dom
    faint in, throttle out.
    Originally posted by 86325LSD View Post
    SO.....
    or
    Thanks.
    Dom
    the 240 has a dual mass clutch on the 318is, if the splines match up and the tailshaft rotates when out of gear and doesn't in-gear I would think you are okay.
    If you're going to be running a single mass m20 flywheel use the euro 323i throw out bearing. Otherwise the stock one from the 240 should work with the m50 dualmass flywheels.
    91 318i | 87 535iS
      thanks. thats an excellent method for testing. did not think of that. thanks again Schpanky
        This is the exact same combo I have, It's perfect for a daily.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
          i wanna know about the 220? sorry had to ask
