s52 flywheel with stock m20 clutch?
  • Thrizzle
    • Aug 2011
    • 194
    If I were to use the stock single mass m20 flywheel I'd either have to shave it, or shave the oil pan. But I have an s52 flywheel also, so...I've searched a few threads and found contradicting arguments.
    1.Can I use the stock s52 dual mass flywheel with the stock m20 clutch and pp?
    2.How about s52 flywheel, m20 clutch, s52 pp? Is it all interchangeable?
    Thanks for the help.
  • Wanganstyle
    • 2828
    no. different standards. run a complete s52 setup, its much higher rated, setup does not weight more
    • Thrizzle
      • Aug 2011
      • 194
      Right on, thanks for clearing that up.
      • Jand3rson
        • 37587
        This all depends entirely on what transmission you're using.
        • Thrizzle
          • Aug 2011
          • 194
          Sorry forgot to mention, I'm using a 260.
          • Adrian_Visser
            • Jun 2006
            • 2823
            No matter which transmission you use you cannot put 228mm m20 clutch on an s52 flywheel. the s52 pp is made for the 240mm s5x clutch not the smaller m20 one.
            '89 Alpine S52 with goodies
            • Thrizzle
              • Aug 2011
              • 194
              Cool thanks for the info guys.
              • darvo
                • Dec 2010
                • 407
                So they can be used with the 260 if your using FW,PP and disc?
                • Wanganstyle
                  • 2828
                  NO.
                  A G260 can take a complete s52 clutchset.
                  a Zf320 (native s52 transmission) can take a M20 clutchset.
                  clutchset = complete item (flywheel+pressure plate+friction disc).
                  How do I know? actual experience.
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Originally posted by Wanganstyle
                    NO.
                    Actual Experience < R3V.
                    KNOW YOUR PLACE!
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • Wanganstyle
                      • 2828
                      [QUOTE=jrdeamicis;2988147]Actual Experience >>> R3V.[QUOTE]
                      M20+G260+4.10 final drive
                      s52 clutchset (complete)
                      +325i TOURING; gangster status
                      + 3rd world country traffic jam+ wangan run + mountain.
                      = win.
                      • Jand3rson
                        • 37587
                        My bad, I misunderstood him, and I meant to say flywheel, not transmission.
                        Clutch-set has to match the flywheel, not transmission. I are tarded.
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          [QUOTE=Wanganstyle;2988160][QUOTE=jrdeamicis;2988147]Actual Experience >>> R3V.
                          = win.
                          You don't know shit till your on a wangan.
                          BNB Designs
                          Richmond CA
                          Julian 848-248-8029
