junkyard s52
  • jrobie79
    • Mar 2006
    • 2526
    junkyard s52
    so I found an s52 at the junkyard, only 95K miles on it, problem is it overheated. total price for the whole package, w/o transmission (its automatic) is 450 bucks..... problem is it overheated.
    so aside from the usual head gasket repair and probably change some other gaskets, what else am I looking at. they were unable to determine if anythign cracked b/c of the overheating
    question is....is it worth it? how long can it take to get this out of the car. the junkyard will basically do nothing aside from putting it on a forklift to lift it from the engine and drop it into my pickup. I need to budget my time accordingly to get there in time and have enough daylight to get it out.
    any other advice is appreciated.
    1991 318i ---- 308K - retired
  • goarmy
    • Nov 2011
    • 622
    for 450 I think its worth it
    • mbonanni
      • Sep 2011
      • 6236
      have a friend help.
      • cale
        • Oct 2005
        • 2331
        What kind of yard won't take an engine out? Usually they'll at least tear apart the harness and cut mounts/driveshaft and yank it out, not that you want that...
        • jrobie79
          • Mar 2006
          • 2526
          he said he wouldnt because it overheated, so they dont have their warranty on the block or head...only bits like manifolds, TB, A/C compressor, I dunno, its fucked up, but how long can you estimate how long it would take to disconnect electricals, tranny, heater hoses, etc
          • Adrian_Visser
            • Jun 2006
            • 2823
            You could do it in 4 hours with a friend easy.
            There really isn't much to it, unhook driveshaft (4 bolts) cut rad hoses and heater hoses, remove rad, undo x20, undo O2 sensor wiring, undo engine mount bolts, remove airbox, remove ground on passenger side of oil pan, undo wires to fusebox, cut fuel lines.
            Start yanking and watch carefully for anything left connected.
            '89 Alpine S52 with goodies
            • jrobie79
              • Mar 2006
              • 2526
              forgot to mention the car sits on railroad ties and is a good 20 inches off the ground, should definitely help
              • willworkfore30s
                • Aug 2011
                • 1090
                You could probably part it for more than $450. I would definitely get it. I got my m42 out by myself never having done something like that in about 3-5 hours.
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  If the cams and crank look good it's worth $450
                  Originally posted by 325Projectz
                  don't listen to the diagram... listen to mr. swiss.
                  :nice:
                  • greyis89
                    • 230
                    Hopefully the head isn't cracked somwhere. I already gambled on an overheated m50 and that's what I found. Still there are many good parts to be had.
                    • jrobie79
                      • Mar 2006
                      • 2526
                      ok so I am gonna get it, and hopefully with no major damage its just some simple part replacing....
                      do you guys have any suggestions on what i should change/replace while its out of the car on a stand for the first 4 months of my ownership?
                      • Jand3rson
                        • 37587
                        Everything. I would order full top and bottom end gasket and seal kits, and replace everything. If you want to go a step further, you could rebuild the head and the bottom end, but then you're getting into spending some serious cheese. But I would definitely replace every seal and gasket you can get at. Don't forget the rear main, it's easy to overlook while it's on the stand, since you don't really see it (ask me how I know).
                        • jrobie79
                          • Mar 2006
                          • 2526
                          yeah i figured I would get the head at least resurfaced, gonna start reading this part of the forum, until now it was a foreign language to me. hopefully I get it in my e30 by midsummer
                          • Wanganstyle
                            • 2828
                            In my own experience the a S52 overheated will either crack its cylinder head or kill the oil rings on the pistons. The bores may also suffer, if thus the block is dead for stock pistons/rings. you could bore and run ++ rings I suppose if the pistons were still alive
                            Overheating also hurts the piston pin interfaces, rod big ends, crankshaft - depending on the duration/severity of the overheat.
                            oil pump internals may be cooked by the overheating, waterpump/entire water system/thermostat/all hoses should be thrown in the trash.
                            In a Overheat anything is possible, if this was a M54 with aluminum block you would expect the block to weaken and threads for head studs to die. This will not happen to a iron deck block but all the parts will suffer.
                            If you are on a limited budget you may want to stay away from anything that has been prior hurt. if the bores/rings are damaged you are probably best doing a single/double overbore and pistons as well - the skirts get worn - for the newer m54 engines with teflon coated piston skirts you can actually see the gradient of the wear.
                            a healthy $xyz m50 can take a m54b30 crank and be happy as a 3000cc item. I'd rather have a 100% torn down M50 stroked with new everything than a used S52. S52 is almost as expensive to keep 100% as a s54.
                            • MaxBell
                              • 1391
                              This. I pulled a 1UZ a week ago and it was done in 3 hours. Not hard, just make sure you bring the proper tools.
                              $450 is definitely worth it. I paid $500 for my M50B25 that I still just rebuilt.
                              REMEMBER: Be safe and have fun is Rule Number 1.
                              The Epic Unbuild of Clint Eastwood
