Check engine light on a Motronic 1.0 ETA?
    Hi all,
    My '87 325(e) never came with a check engine light, which is normal since it's a Motronic 1.0 car. After swapping in an M50 with DME, is it possible to add this functionality? If I swap the cluster with one that has a CEL, will the wiring be there for it?
    Thanks
    Youre gonna have to add the wiring.
    Check Us out on Facebook
    Full Product Line Tuning
      Give the light switched 12V on one leg of the lamp and the grounding wire from the ECU on the other.
      VOILA! CEL.
      You can get the sockets that slip into the clusters off late model cars, same socket for ABS and CEL.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
        ^ this. When i Do early model harnesses i run the CEL wire from the ECU and a red/white from the harness to the back of the cluster.
