Leaky oil in M50
  • KangamangusDriver
    • Aug 2005
    • 1870
    Leaky oil in M50
    I have aquired a leak in my oil pan where the oil pressure/level sensor bolts up. I replaced the o-ring on the unit and still leaky. Has anyone had expierence with this similiar problem??? Could the actual sensor leak internally?? Any insight would be much appreciated!!
    Thanks!
  • joshh
    • Aug 2004
    • 6195
    I don't think the sensor can leak out the bottom like your thinking. Did you clean the area where the o-ring touches really good? and did you put just a tiny bit of oil on the ring itself?
    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
    • arsevader
      • May 2005
      • 1025
      The M20 pressure sensor is notorious for leaking internally. The plastic cracks, allowing oil to pass out the sensor and travel along inside the harness.
      Very common problem. Do you use the M20 sensor with the M50 swap?
      James
      • KangamangusDriver
        • Aug 2005
        • 1870
        I cleaned the area very well and that is why I am wondering if the sensor itself is leaking. I used the original sensor with the swap, so M50 sensor.
        Thanks for you help!
        • arsevader
          • May 2005
          • 1025
          The ETK lists the switches as the same part for the M20 and the M50 so I'd bet that is where your problem lies. The switch is pretty cheap so I'd just replace it.
          James
          • KangamangusDriver
            • Aug 2005
            • 1870
            We are talking about the oil sensor on the bottom of the oil pan correct?
            • arsevader
              • May 2005
              • 1025
              I was actually talking about the presure switch which now I see on the M50 is located in the oil cannister. BUt I don't see why the same problem couldn't occur there. If you are sure you've cleaned it well then it is probably the sender.
              James
              • joshh
                • Aug 2004
                • 6195
                I thought he was talking about the level sensor at the bottom of the oil pan. I have 2 of them and either one is cracked.
                • arsevader
                  • May 2005
                  • 1025
                  Yeah I see that now.
                  Still, if he installed them properly they shouldn't leak.
                  James
                  • KangamangusDriver
                    • Aug 2005
                    • 1870
                    The official name of the part is oil level switch, mounted on the bottom of the oil pan on a 95 M50.
                    Has anyone had these ever leak on them?????
                    1. Was it the seal/Rubber o-ring???
                    2. Was it the actual switch??
                    Sorry to cause any confusion
                    Thanks
                    ***UPDATE***
                    I found the problem. Just wanted at add closure.
                    It was the damn o-ring on the dip stick tube!
