longer than normal crank time
  • scottinAZ
    • Dec 2009
    • 1312
    I have just over 10K on my swap (94 M50TU into 87 cabbie) and am now getting an intermittent issue with cranking times.
    Normally it will start almost immediately, however on occasion it will take up to about 5 seconds (or a bit more) for the engine to fire.
    what would cause that to start now? leaky injector? Bad Relay, FPR taking a shit?
    want to nip this in the bud before it becomes a more annoying issue
    I saved 15% on my Bimmer parts by switching to ...
  • Adrian_Visser
    • Jun 2006
    • 2823
    There is a check valve on the outlet of the fuel pump that can sometimes quit and cause longer than normal cranking times, I don't know if it would cause a five second crank though.
    '89 Alpine S52 with goodies
    • JTapper
      • Sep 2009
      • 847
      Sounds like a crank position sensor failure. I'd test it for resistance.
      Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
      • 328ijunkie
        • May 2007
        • 3961
        Relays.
        Check Us out on Facebook
        Full Product Line Tuning
        • scottinAZ
          • Dec 2009
          • 1312
          Originally posted by 328ijunkie
          Relays.
          changed, and seems to be working.....
          Fuckin 20 yr old relays....
          • ak-
            • 12422
            Fpr was the fix for me.
            1991 325iS turbo
            • MaxBell
              • 1390
              I had that in my M20 and the fuel pump was the problem.
              REMEMBER: Be safe and have fun is Rule Number 1.
              The Epic Unbuild of Clint Eastwood
