Drive shaft help?
  • M///BMW
    • 216
    Drive shaft help?
    I know this topic has been covered numerous times but no one has a solid answer on this. Will a 99 AUTO M3 drive shaft mount to a ZF 24v? Is the auto drive shaft longer?
    What other options are available? I heard the E46 328i drive shaft is another option?
    I know the E30 M3 drive shaft will work.
    I know the MANUAL 97-99 E36 328/M3 will work.
    Thanks.
  • brokenbimmer533
    • 317
    From what I read while researching for my swap, auto ds will not work. They are longer I believe. Some eta ds will work as well.
    Edit: I also thought it was 96 to 98 328/M3. Regardless, the key here is 4 bolt diff flange, 148xmm length, no CV, and 3 bolt trans flange (96mm for zf)
    • 328ijunkie
      • May 2007
      • 3961
      autos are way SHORTER..
      Check Us out on Facebook
      Full Product Line Tuning
      • MaxBell
        • 1391
        Yep. My M50 swap confirms this for me.
        REMEMBER: Be safe and have fun is Rule Number 1.
        The Epic Unbuild of Clint Eastwood
        • M///BMW
          • 216
          Okay. Thanks.
          • brokenbimmer533
            • 317
            Ooops my bad. Sorry for the wrong information. Longer/shorter...won't work regardless.
            • SwiftE30
              • Jun 2010
              • 998
              Thanks.
              the 97-99 M3 needs to be a 4bolt. most of them were 6bolt rear ends. so make sure you know that. and then check out the revshift new 24v swap guibo..
              https://www.revshift.com/shop/index....fd9156854e3c7e
              allows you to keep the e30 DS. i found this to be way easier and cost effective.
              1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
              • JdmEuroNorth
                • 222
                E36 318Ti and 325I drive shafts will work with a custom hanger bearing mount.
                Function.
                Form.
                • M///BMW
                  • 216
                  Learned something new today. Thanks.
                  Has anyone heard of the E46 328i driveshaft being a mate for 24v's?
