Starter not turning m50 over
  • MaxBell
    • 1391
    Did you shave your flywheel?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • jrdeamicis
      • Nov 2008
      • 956
      Pull the engine ASAP and re-torque the rod bolts. At the same, check everything else.
      When you put it back together put a real ground cable on the block.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • hwy84
        • Aug 2009
        • 190
        Re-torque for sure...
        And +1 to the unshaved flywheel. If you're using an M20 fly, and you didn't machine the back of it... you've found your problem.
        Current:
        1991 325i Sedan - S50 Swap
        1988 325i Cabrio
        Past:
        1991 M3
        1991 318is
        1985 325e
        • xwill112x
          • Jan 2009
          • 4236
          My money is on the flywheel wasnt shaved.
