What do you guys think about a 4.10 with the ZF?
  • Eric
    • 5142
    I'm running a 3.73lsd right now and hardly use 5th on track, so i've been thinking of going to a 3.91 for a while, but a 4.10 small case might be really cool!
    Also do you think a small case diff can handle 250rwhp?
  • trackjunkie21
    • Jan 2010
    • 3962
    No way it will handle that power, my small case crapped out behind an m50, and why would you want such short gearing? 4.10 with my g240 was horrible, can't imagine with a ZF
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • drumad
      • Aug 2009
      • 1700
      why not a 4.10 med case? I don't know the weight difference between a small and medium but I can't imagine it to be too much.
      2008 335i - n54b30
      1991 318i - m52b28
      1994 fzj80 - LAND CRUSHER
      • trackjunkie21
        • Jan 2010
        • 3962
        Don't know exact numbers, but it is substantially heavier, but I wouldn't skimp on something like that, medium case all the way.
        • The Dark Side of Will
          • Jun 2010
          • 2796
          The weight difference is 20-25lbs... not a big deal, but not zero.
          Do you have a small or medium case now?
          Obviously you can't use first with gearing like that. If you dropped you FD to the point that you could use 5th, would you end up not using 2nd?
          • e46s54dr
            • May 2008
            • 1059
            The small case lsd's tend to overheat and fail alot sooner just based on the principle that its smaller and has less leverage between the dog ears and clutch disc. Though its 20lbs lighter than the medium case version, Id stick to the larger one.
            • Eric
              • 5142
              What kind of driving are you doing? I'm sure drifting will cook a diff fast, but I think I'm pretty smooth on track...
              I figure if I'm going to go up in ratio, might as well try and save 20lbs.
              I currently use 2nd very rarely, and my euro S50 has enough torque to pull out of tight corners in 3rd. I was actually downshifting into second in places that 3rd ended up being faster.
              Hmmm, so to counter the overheating I'd have to install a pump and heat exchanger which would negate the 20lb weight savings... well that sucks. Does the Z3 diff cover fit on the small case?
              • Jonny Cash
                • 1763
                M- coupe cover, and the thickest heaviest duty gear oil you can find.. Do it.
                Dont let anyone who hasnt used high heat fluid in a small case tell you that it will blow. Go out there and find out first hand, and post pics of the carnage!
                -Jay
                2014 NASA FL se30 champ #81
                2001 se46 3 year plan in progress
                • Eric
                  • 5142
                  :rofl::rofl:
                  I'll definitely be packing my current 3.73 as a spare!
                  • e46s54dr
                    • May 2008
                    • 1059
                    According to Vac and Turner, the M-Diff cover should fit on the both the small case and medium case.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      This is my daily car with some spirited driving here and there.
                      • nrubenstein
                        • 3148
                        It'll be pretty hideous on the highway, but should be fun on track. Assuming that you have an 8k rev limiter, you'll be running out 5th on a lot of tracks, though.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • Wanganstyle
                          • 2828
                          BMW makes the 168mm and 188mm differential units. The 188mm case housing has a different # of bolt holes than the 168mm unit.
                          Z3M diff cover was designed by bmw for the Z3M (all 188mm units). One can X reference the Part number of the paper gasket between the 168/188mm units to see the difference
                          The thermal stress is less a worry than the torque of a healthy 3000cc engine. the 168mm units have a brittle top cap that shatters - a billet top cap would remove this problem. Differential internals are another issue; the 168mm design does not allow additional clutch discs/steels to be added with out custom modification. 188mm differential units were designed to allow easy configuration to suit quite a few OEM applications.
                          168mm stock LSD rebuilt to 100% oem stock specs may not handle real slicks on track for extended periods; the original organic clutch disc material is often seen melted in stock 188mm diffs.
                          168mm ring and pinion themselves are not rated for 3000cc power but will take it if ran with cooler on the track with a kind driver.
                          if driver does run the car hard a modified 188mm unit would be much advised. OR a high quality Aftermarket LSD in 168mm like a KAAZ or OS Giken unit.
                          4.10 would be great for short tracks with 8k rpm; an overdrive 6th gear would be nice if car is not trailered to the track.
                          pictured below is what happens to 168mm OEM LSD units.
                          Ring and pinion were undamaged, diff clutches and internals still in operational order. The bearing caps were keeping this entire unit togeather
                          This 168mm LSD was paired with a 100% stock M42 1900cc of fury. 100% stock car. Halfshafts un-damaged, diff mounts and bushings undamaged.
                          • e46s54dr
                            • May 2008
                            • 1059
                            ^ Youre correct, on their website they say it will fit both 325i/e and m3s. I thought the e30 m3s came with the small case but they come with the medium case lsd after all. So the cover will only fit the medium case.
                            • gobuffs
                              • Dec 2004
                              • 513
                              I ran a 4.10 (medium case) on my Euro 3.2 years and still run it on my S54. With the tires I'm running the theoretical top speed is 153. I was hitting 143 at the end of the back straight at VIR. A better launch out of oak tree I could be nudging the speed limiter. I don't see many tracks where I'd need more than 153...maybe in the future.
