need hlp with 2 things
  • KillaCam
    • 2103
    so i have e28 mounts but with them i don't have room to fit any exhaust with my stock exhaust m50 manies..
    do i need to change the exhaust manifolds or what.. or do i have the wrong e28 mounts.
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • 328ijunkie
    • May 2007
    • 3961
    What do your mounts look like and you usually have to get custom downpipes made no matter what.
    Check Us out on Facebook
    Full Product Line Tuning
    • cabin
      • Dec 2006
      • 552
      This.
      You need to modify the downpipes or go custom.
      -Justin
      Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
      • KillaCam
        • 2103
        i don't have the green ones or the m5 ones.. i have the 528-535(1986) ones.
        Originally posted by cabin
        This.
        ya im not worried about that i have a welder and some basic skills... so that shouldn't be a prob.
        but i did some searching and found you need to shim the mounts some to make the downpipes clear the front sub.
        I'm going to shim it and see what happens
        • e30rapidic
          • 2167
          you can shim but chances are you will need to modify/create new downpipes.
          '87 325ic, powered by S50.
          • SwiftE30
            • Jun 2010
            • 998
            anyone have pics of their modifications? planning on getting some m50 mani's and midpipe sections and welding up an exhaust this weekend.
            1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
            • Fusion
              • Nov 2009
              • 3659
              One washer between the M5 green mount and E36 motor mount did it for me, but its damn close both on the subframe side and passenger foot well, I can hardly push a saw blade in between.
              I have what seem to be supersprint kopi headers.
