m52 e30 with the OE cluster in it and its reading higher than it should, its basically past pegged out/wrapped at 40-50 mph.
ive read on some threads posted here that this might be the result of not using a 6cyl coding plug, is this the case?
or
do i have a bad cluster/seperate issue than the above?
edit: after some more digging it seems as though the coding plug probably is the issue. took me a while to find the PN but everything is all good.
my apologies for the premature posting!
or
