Okay… I’m thinking about rebuilding my m50, I think it’ll be pretty equivalent to getting a new engine shipped here, I have a few questions though.
I’m planning on doing a stroker motor using a 3.2 crankshaft, rods and pistons. One of my main concerns is camshafts. I’m assuming I should use the 3.2 camshafts as well. I’ve heard that you need to stick with OBD-2 cams for obd-2 car and obd-1 cams for obd-1 cars (that’s what was on lukas’ old site)… I don’t see how it matters at all. They all use the same cam gears etc. etc. It seems like I should be able to run 3.2 cams without any problem- especially considering custom software doesn’t apply to me because of the stand-alone system. Incase anybody is worried, I plan on a port and polish.
Is there any way to “delete” the vanos system? I have no use for it.
I also need help demystifying the main bearing shells. ETK has a million different shells, different colors etc. What does all of that mean? I’m assuming that when buying shells/gaskets etc. that I’ll want to get them for the m50, rather than an s52… with the exception of the head gasket of course.
When using the 3.2 crankshaft, should I get the main seals for the s5x, or the m50? The rear seal is the same part number, but the front timing case seal is different. Is this because of the crankshaft, or the timing case?
Does anybody know of a gasket kit that takes care of all engine gaskets? Or just a rebuild kit- I wont need pistons, but pretty much everything else...
I’m sure I’ll have lots more questions, but I think this does it for now.
Thanks-
Addis
Thanks-
Addis
