c104
  • umana12
    • Jul 2011
    • 20
    c104
    Hi guys. I got an 86es with an m50. The wiring is all hooked and I get spark but no fuel. I've been readin about people wiring their c104 but noone has given a specific answer on where to wire pin 2, which is for fuel. Wanted to see if anyone on here knows to which wire I would be connecting this to. Thanks for the help :)
  • lolcantturn
    • 4588
    You can skip all the pins on the C104 and your car will still fire.
    Originally posted by TSI
    OEM+
    • umana12
      • Jul 2011
      • 20
      On the early models u need pin 2 to start pin 1 and 3 for mpg and rpms
      • 328ijunkie
        • May 2007
        • 3961
        You dont need pin 2 to start.
        Check Us out on Facebook
        Full Product Line Tuning
        • lolcantturn
          • 4588
          ^this. You don't need the C104 to start. All C104 is, to my understanding, is tach, econometer, and VSS, all nothing related to spark or fuel to start the car. Check your wiring.
          OEM+
          • umana12
            • Jul 2011
            • 20
            2nd post
            • lolcantturn
              • 4588
              No, that runs in conjunction with the VSS which is not necessary to start.
              OEM+
              • 328ijunkie
                • May 2007
                • 3961
                C104 doesnt have VSS in it at all.
                • umana12
                  • Jul 2011
                  • 20
                  I have read in a few spots that for my year I have to have pin 2 wired..I have checked my wiring and I only get fuel if I bypass the fuel pump relay
                  • lolcantturn
                    • 4588
                    Think I read something in Beej86's thread about the VSS in the C104. Whatever I've never had an eta so I wouldn't know.
                    OEM+
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      VSS is not in the C104, you have to wire it from the back of the cluster, this is why alot of times people have problems with soft rev limiters in early model cars, they forget to hook up the VSS.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • Beej '86 325es
                        • 2639
                        Pin #1 BLK - Engine speed
                        Pin #2 Not used
                        Pin #3 YEL/WHT - Fuel rate gauge
                        Separate from the C104 plug, you need to tap into a signal wire on your speedo for your Vehicle Speed Sensor. I tapped into a BRN/RED wire on the plug on the back of the speedo.
                        -Brandon
                        '86 325es S50
                        '12 VW GTI Autobahn DSG
                        '03 540i M-Sport (sold)
                        '08 Jeep SRT-8 (sold)
                        For sale:
                        S50 TMS chip for Schricks
                        • umana12
                          • Jul 2011
                          • 20
                          beej wut wire did u need to connect on c101 then for fuel??
                          • umana12
                            • Jul 2011
                            • 20
                            if u can check page 1360 in here..
                            • Beej '86 325es
                              • 2639
                              Pin 24 on your x20 plug should be a WHT/BLK wire. Connect to that.
                              -Brandon
                              '86 325es S50
                              For sale:
