Electric cooling fan question !
  • NERDE30
    • Oct 2009
    • 133
    Would a 16in pusher electric fan blowing 1500 CFM's be enough to keep my S50 swapped E30 running cool ?
  • sharky
    • Jan 2005
    • 2672
    yes
    • 328ijunkie
      • May 2007
      • 3961
      1500 is a little low.... Stock fan pushes more.
      Check Us out on Facebook
      Full Product Line Tuning
      • NERDE30
        • Oct 2009
        • 133
        Damn so what should I be looking for as in CFM range
        • sharky
          • Jan 2005
          • 2672
          you will be fine, ran a 1600 w/ S52 supercharged and never had a issue, low temp thermo, mishimoto rad, BMW coolant 50/50 w/ watter wetter
          • NERDE30
            • Oct 2009
            • 133
            OK cause what I have as of now is M42 rad, slim fan 16in , new thermo , I am gonna have to grab some of that spiffy BMW coolant
            • Jand3rson
              • 37587
              That's what you should be using on the 24V motors, anyway.
              I have a 16" SPAL puller on my M42 radiator, and it does the job just fine! Just make sure you fab up some actual brackets for mounting it, don't use those little zip-tie things that come with it, you will ruin your radiator.
              • polkadot_boxerman
                • Sep 2007
                • 102
                any pics of your brackets?
                • samiam3356
                  • Jul 2009
                  • 1901
                  Massive's brakcets are nice!
                  Here's mine
                  The brackets
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • 36brua
                    • 689
                    Will Massive brackets ^ work on stk 89 radiator for 'puller' fan /? thanks
                    My CA legal M60 swap
                    The happening in our garage
                    • Den_k321
                      • 1248
                      any links where to buy those 1600 or 1500? thanks.
                      1988 325is S50 in-progress.
                      http://www.facebook.com/E30LocalCrew
                      Few pictures:
                      http://www.r3vlimited.com/board/showthread.php?t=255061
                      • Jand3rson
                        • 37587
                        Here's my brackets:
                        Simple, and probably cheaper to make than Massive's overpriced stuff.
                        • samiam3356
                          • Jul 2009
                          • 1901
                          Wouldn't take too much ingenuity to come up with something.many have got by with the plastic zip ties.I don't like them but a few drifting buddies have used them without issue.
                          $5 shipped?
                          • Jand3rson
                            • 37587
                            Those plastic zip ties are serrated, eventually, they will vibrate and cut through the fins of the radiator.
                            • Toadleg
                              • May 2011
                              • 209
                              I had a similar set up and it worked good on the hottest of days(seattle).......however on the track when the engine would see high rpm's for a long time it would get way to hot. The fix for me was the thicker IE radiator
