M50 E30 Spongey Brakes
  • MaxBell
    • 1391
    Hey guys;
    I have just put my E30 back on the road, now with an M50!
    However, my brakes don't feel strong at all.
    I can pump them at a stand-still and they are very firm, I can't get the pedal to the floor at all.
    However, as soon as I am moving, I can push the pedal to the floor. This slows the car down, but I doubt I could lock up the wheels.
    I know there is a vacuum leak somewhere in the engine, because it takes a second to return to idle from throttle. Could this be affecting my brakes, through the booster?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • 328ijunkie
    • May 2007
    • 3961
    What booster?
    Check Us out on Facebook
    Full Product Line Tuning
    • MaxBell
      • 1391
      The 325i booster that I moved over slightly to fit.
      I spoke to some friends today and they seemed to think the master cylinder was shot.
      • trackjunkie21
        • Jan 2010
        • 3962
        Iirc most people who ran the booster moved over have some sort of issue like that.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • jaywood
          • Jul 2010
          • 4528
          Check your fluid level.
          Maybe you have air bubbles in the brake fluid?
          Could be a weak spring in your master cylinder.
