Fuel cut on left handers
  • Ara
    • Jan 2006
    • 365
    So the story goes.....i went with a walbro in-tank pump and just ran a line for the exterior fuel pump. When the car is low on fuel ( below 1/4 ) it cuts fuel and a second later the car turns off. Aside from keeping the car above the 1/2 mark , is there anything else that could remedy this? perhaps picking up an Aeromotive FPR?
    car is a S52 OBD1
    thanks
  • FredK
    • 14762
    That is odd that you're experiencing fuel cut on left handers--most people have problems with right handers.
    Jim Levie has a solution to the problem, which is to add a second pump to the left side of the tank.
    • 328ijunkie
      • May 2007
      • 3961
      You prob mounted the pump too high up on the bracket.
      Check Us out on Facebook
      Full Product Line Tuning
      • Ara
        • Jan 2006
        • 365
        Thanks for the replies guys.
