Help! - Need a Thin Fan
  • Slovik
    • Jan 2010
    • 198
    Just put my after market e36 radiator in yesterday and I only have about 1.5 inches from the radiator to the threaded nose of the water pump. I would like to run an electric fan and I can offset it a bit. What are you guys running and where did you get it. I am assuming that the e30 325 clutch fan won't fit, is that correct? The car is a 91 318is w/s52 engine.
    Thanks,
    Seth
  • drez14
    • Jun 2011
    • 211
    i used this 12 incher in front of my Mishimoto e36 radiator.
    I had to mount it more towards the drivers side of the radiator and trim some of the plastic so that i didnt hit my fan delete nut
    • 328ijunkie
      • May 2007
      • 3961
      Just put a pusher in there.
      Check Us out on Facebook
      Full Product Line Tuning
      • 325e10
        • 161
        I put a 16" pusher in place of the stock Aux fan. Works great.
        • Slovik
          • Jan 2010
          • 198
          I like the idea of just running a pusher, I have a/c and it's real hot down here, is the just a 16" still the way to go. Which ones are most effective?
          Thanks,
          Seth
          • e30 s52
            • 100
            just change the thermostat and switch and use us auxillary fan....eliminate the clutch fan
            • bubbajan21
              • 1962
              Originally posted by slovik
              i like the idea of just running a pusher, i have a/c and it's real hot down here, is the just a 16" still the way to go. Which ones are most effective?
              Thanks,
              seth
              spal
