just got done swapping in my 94 M50tu into my 1990's 325i and im having a acceleration issue.
Keep in mind, the car doesnt have Cats, just a straight pipe all the way back. the check engine light is ON, i changed the fuel filter ( with no success) did a fuel pressure test (turn out okay) i notice that i had a coil that was sparking when the car was running so i swapped that out and also the long boot too... and it seem to fix the problem...till the next morning. it went back to misfiring and sputtering at 3k
im guna change the spark plugs cause i put some champions in them....
would that be the source of the problem since there just some "Ol spark plugs" ????
