Let's talk bottom end rebuilding.
  • lolcantturn
    • 4588
    I'm picking up an M50 Vanos long block from a good member here (gp.plus) which will be the candidate of a long term "whatever money I have left from my paycheck" turbo build. It has 180k, which I'm sure is not good preferred since I plan on getting the block O-ringed and making >400whp.
    Now I'm curious, is it better to rebuild this 2.5L M50 bottom end with new piston rings, bearings, and main bolts, or rather find a lower mileage 2.8 M52 block?
    As far as bottom end rebuilding goes, to what extent will machining play a role? I assume that I simply cannot buy piston rings, but find out the exact measurements of the cylinder and custom buy the rings?
    Originally posted by TSI
    OEM+
  • VinniE30
    • 2113
    What's wrong with the NV M50 you already have?
    I would go with the 2.8 M52 anyway, you won't have to run as high pressure as with the m50 to make the equivalent power because of the larger displacement.
    Zinno '89 <24v swap in progress>
    • lolcantturn
      • 4588
      I would be building the motor turbo outside of the car, this means I can still drive it ;)
      And that's exactly what I was going for.
      OEM+
      • 328ijunkie
        • May 2007
        • 3961
        M52. /thread
        Check Us out on Facebook
        Full Product Line Tuning
        • NbAmTwE
          • Jul 2010
          • 148
          isn't it aluminum though? M52 I mean.
          UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
          stripped out e30 rally project - in progress
          M50NV -> M50TU E34 swap underway
          • 328ijunkie
            • May 2007
            • 3961
            all except the 97-98 Z3s had cast iron bottom ends. M52TU's were all alum.
            • Beej '86 325es
              • 2639
              Just be careful which M52 you buy. Years back I bought a Z3 aluminum block bottom end that turned out to be an M52TU from a '99, which has different oil/coolant passages. '97-'98 should be ok though, as 328ijunkie said.
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • Adrian_Visser
                • Jun 2006
                • 2823
                ^^^Not for boost. The alloy blocks have a habit of pulling head bolt threads under boost, besides good luck finding one if that was what you wanted. They are pretty damn rare.
                BTW I choose option C) use 2.5L block and 84.5mm bore and s52/m54 crank. This gives you a 3.0L Franken stroker with lots of meat between the cylinders for HG sealing.
                '89 Alpine S52 with goodies
                • NbAmTwE
                  • Jul 2010
                  • 148
                  This is a good idea, I've always wanted to do a Frankenstein motor.
