Can't Twist the Shift Selector 10 degrees
  • graphikg
    • Jan 2008
    • 1614
    I am doing the rear TABs and the subframe bushings, so I have the diff and driveshaft out etc. I decided to mess with the shift selector rod 10 degrees to get my shifter position to normal but DARN! This thing wont budge. I tried torching it for over 5 mins until it is hot, but it still wont twist. I am using my arm strength - any suggestions?
  • ieatpeople
    • Mar 2008
    • 883
    use some pliers like channel locks or vise-grips.
    Originally posted by BillBrasky
    That's like Vlad challenging Chip Foose to a car painting contest.
    Originally posted by acolella76
    i'm pretty sure 'Phillis' is short for syphilis
    2007 CVPI, stock and slow
    1994 tercel, 5efhe swap, i/h/e
    1984 t-type, 5.3/th350 swap in progress
    My newest addition:
    Rebecca Arlene, born 4/19/2013
    • SkorcherX
      • Jun 2011
      • 267
      I grabbed a deep 10mm socket and my longest socket extension. I put one end of the shift rod in the vise and slipped my socket+extension over the shift rod. I then used a little butane torch to heat the center section, then just started applying my body weight to the socket extension. It then began to turn.
      I ended up having to bend it twice as the first time I didn't get the full 10 degrees.
      Hope this helps.
      • N2MYE30
        • Oct 2007
        • 5536
        Me and a bud used iirc a couple of vise grips and moved with ease.
        COTM
        • graphikg
          • Jan 2008
          • 1614
          I did use the vice grips - but I guess I need a table vice.
          • Adrian_Visser
            • Jun 2006
            • 2823
            You need a vice. I think I used a crescent wrench on the fork to twist mine.
            Three sockets taped in a vice to make a bending jig to shorten it.
            '89 Alpine S52 with goodies
            • SwiftE30
              • Jun 2010
              • 998
              definintely need a table vice. Heat it up and get something with legitimate leverage and you'll be shifting straight in no time.
              1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
              • Danny
                • 14216
                I didn't use a vice. What are you heating it with? I used oxy acetelyne.
                • graphikg
                  • Jan 2008
                  • 1614
                  I am just using the benzomatic torch. Maybe it is not sufficient? I need a vice for sure.
                  • camshaftgsxr
                    • Aug 2011
                    • 416
                    heat it more and apply more force
                    BroWorks.com Bro is a lifestyle
                    • Jand3rson
                      • 37587
                      You can have mine if you want it, pay for shipping, and it's yours. Twisted to 10°.
                      • SwiftE30
                        • Jun 2010
                        • 998
                        ^^super good deal. I almost want it for a spare. shipping to 98040?
                        • Jand3rson
                          • 37587
                          If graphikg doesn't want/need it, I'll let you know. :up:
                          • e30rapidic
                            • 2167
                            we also slipped jack handles over the vice grips for leverage
                            '87 325ic, powered by S50.
                            • El Gato Liso
                              • Jun 2008
                              • 44
                              lol...
                              when i did this, i literally took each end of the selector and put it into the ring part of 2 spanners. it twisted with no effort. piece of cake!
