So i have been having trouble getting my engine to start. (No spark, No injector firing, no icv sound at turn key, no cel). As I hunt as to why my dme is not powering up, i check power at dme (413 Red, pin 26 - has constant power). I checked the dme relay pins (at relay) and pin 8 and 9 have power. I go back and check the dme relay wires to the dme (those pins have no power). I added an additional ground (strut tower to ground on dme relay) to the dme relay, which turned the CEL on, icv hums, and i can hear the fuel pump prime. But the icv doesnt turn off when key is out, and still does not fire.
any specific ideas on what to check? Im trying to get this thing to run, because shops will charge way too much for this work. Only problem is i am still learning electrical work, and about this engine.
Any help is much appreciated!
'95 s50 and harness from the same donor car
413 red dme
413 red dme
