What driveshaft do I need???
Is my best option to install a diff, install the engine / trans and then measure the distance between the two?
Someone has to have done this. As far as I know the ZF 320's are the smae length so anyone running an S50 / ZF should have the same setup, correct???
I understand that this trans only came out of select e34's and a few e36 328's.
It just happen to be attached to the M50NV I have to go in my car.
I've been reading and am more confused than ever with talk of flipping the center bearing depending on driveshaft, etc.
Does someone know what I need??
Please Help!!!!
Please Help!!!!
