Hey all,
Looking for some advice from the gurus please.
I purchased a M50B25TU swapped '88 325 (motor supposedly has ~130k) a few months ago and recently noticed a ton of white-ish smoke coming from the exhaust.
I had made a left-hand, quick turn, into a CVS entrance the other day and noticed lots of smoke in my rear-view mirror. I had been driving for approximately 20 minutes at that time and have never noticed any smoke since purchasing the car. The smoking continued for the next 15 minutes until I arrived to work but seemed to be decreasing in amount. I did not notice any more smoke from the exhaust for the rest of that day (lunch drive nor on way home) and for the next few days.
Tonight I again noticed whitish smoke coming from the exhaust as I parked after driving ~6 miles to the gym. It had a slightly sweet smell though was hard to ID however I am leaning towards coolant based on the color and amount. That first time it was like I had sea-foamed the motor.
The car seems to be running perfectly and is not hard to start nor seems to be missing or low on power. I have not noticed any milkiness to the dipstick. It revs fine all the way to the limiter and the coolant temp needle doesn't seem to be abnormally high (if anything, a bit lower than usual).
Should I perform a compression test this weekend? Sound like a headgasket issue?
The only other issue I can think of is potentially the vanos making a slight-rattling noise. Could a vanos problem lead to smoke from the exhaust? The car is my daily-driver and I need to make it to work the rest of the week
Thanks in advance for any help and I hope I've made some sense...
Dustin
Dustin
 Help - White Smoke
									Help - White Smoke
