i noticed something on my ZF 320 that's waiting to be swapped in. normally the gear selector should rest in line with the 3rd and 4th gear and you can twist it to the left (1st and 2nd) and to the right (5th). on mine i can only twist it to the left that makes me think that it's sitting by the 5th gear. ... i just literally thought that i should check if i can push it in in that position to make sure it's really sitting there but if it is what can be a problem? i know almost nothing about the little bits and pieces inside the transmission. is it a broken spring or something?
Thanks for the help in advance!!
