s52 w/ 506 dme CEL Reset
  • drez14
    • Jun 2011
    • 211
    Hi Guys,
    While trying to troubleshoot my CEL woes i was trying to troubleshoot why my CEL wouldnt reset with the stomp method. For the longest time i would do the 5 stomps and it would continuously repeat the same code, so i thought i only had 1 error. The problem was that after holding the pedal down for the 10-15 seconds, it wouldnt reset.
    Out of frustration, i tried a different method. After the first set of codes were displayed, i did another 5 stomps, and whaddaya know. Another code surfaced. I kept doing the 5 stomps after the 1 long code until the first code repeated. After that i was able to hold it down for 10-15 seconds and it reset.
    Im not sure if this procedure is posted on this board somewhere, but every one i have read says that it automatically goes through all the codes until all codes have been read.This was not the case for me.
    Anyways.. Just a heads up to those who are having trouble resetting their DME with the stomp method.
    Try this method and it might work out for you.
    s52 swap obd1 swap
    506 dme w/ bonnville/conforti chip
    e36 s50 harness
